[SOLVED] About the on-board debug solution on Cypress(Spansion) S6E2CC
  • [SOLVED] About the on-board debug solution on Cypress(Spansion) S6E2CC
    Hello Mr./Mrs.,
    My name is Tsung-Ming, Shen. I am a user for using Spansion S6E2CC on SEGGER Embedded Studio for ARM.
    I followed the guide on your website:
    studio.segger.com/packages/ind…packages/ses_doc_home.htm
    and
    but the troubleshooting seems not to work on my situation, and I cannot find anyone who has the same problem before on the internet.
    [/quote][img]https://mail.google.com/mail/u/0?ui=2&ik=b6a33cebc0&attid=0.0.1.1&permmsgid=msg-f:1671639202182056200&th=1732daff66adc908&view=fimg&sz=s0-l75-ft&attbid=ANGjdJ_sihm52QhcVP3tDIHJTCLJSqcSY-a7aWWMnCsj3mB29O4K_gXiCQeFuG_ktjq1o0wHd6BXg9plnUNC2xx-8XjmVa9JO7Dsag9WzbeXrhAWgI9wfEMcLkpZMbU&disp=emb[/img]
    I followed the FAQ and check the windows device manager. I cannot find the J-link device(maybe because my device is just supported but not really a J-link device)
    [img]https://mail.google.com/mail/u/0?ui=2&ik=b6a33cebc0&attid=0.0.1.2&permmsgid=msg-f:1671639202182056200&th=1732daff66adc908&view=fimg&sz=s0-l75-ft&attbid=ANGjdJ_NujNWPgj94dUySPdL0cqubYujV8Na5P4o1nWmDSh8QcGpUUkseMJGpzPOsNVqJudChYBX46Cp_J9DscjRLC-NkxfwmKxFAX0h3fgHywoU7NGh2BzSghiODEI&disp=emb[/img]
    On Windows device manager is called CMSIS-DAP Spansion Virtual Communications Port.
    Thus, the FAQ method seems not working for me.
    I tried the following website:
    segger.com/products/debug-prob…links/j-link-ob-spansion/
    because my board(SK-FM4-176L-S6E2CC) is also on the supported list.
    I follow the instructions only My Hex file is not called J-link OB...srec.
    I can not find such a file in my CD only SK-176-s6e2ccTestCode-V12.srec.
    I'm not sure where the problem is and how to solve it.
    I tried everything I can do but still not work.
    Could you kindly help me to teach me how to solve this problem?
    [/quote]
    It appears the guide is a bit outdated. I assume you are stuck at the part which says to install J-Link drivers with COM support.
    Just download and install the latest J-Link software and you should be good to go:
    segger.com/downloads/jlink/
    Should that still not work please note that we do not provide any support for the conversion to J-Link as stated in the guide.
    As the Spansion Board you are using features a 9-pin debug header for external debug probes we recommend getting a proper J-Link + Adapter.
    If you are using this setup for educational purposes you can use a J-Link EDU or J-Link EDU Mini:
    segger.com/products/debug-probes/j-link/models/j-link-edu/
    segger.com/products/debug-prob…k/models/j-link-edu-mini/
    For commercial usage at least a J-Link Base is required.
    When using the full size J-Link with the 9-pin interface the following adapter is needed:
    segger.com/products/debug-prob…s/9-pin-cortex-m-adapter/
  • Hi Nino,
    I checked my J-link driver, it's the latest.
    I am not really sure the meaning of "we do not provide any support for the conversion to J-Link as stated in the guide.", so you means the board Cypress(spansion) S6E2CC can not directly develop on Segger Studio?
    And my board is using a USB cable (A/micro-B) to connect the computer, so you means if I want to use Segger studio, I have to use 9-pins debug header with J-link EDU or EDU Mini?
    Thanks for answering my question! It's help a lot! Thanks
    Best Regards,
    Tsung-ming
    No, it just means that if you run into some issue with the guide we are not allowed to provide support for it.
    Yes.
