ROM usage of Appwizard
    • ROM usage of Appwizard
      I am working on a project with appwizard and I realised that about 66kB of ROM are used for unicode even when if the "support bidirectional text" is disabled in the project options.
      I read the doc for emWin, which says that about 60kB of rom is expected to be used as soon as GUI_UC_EnableBIDI is linked, but it is only present in the code when the option is ticked in the project option, and it currently isn't.
      Am I missing a define somewhere? the only place where i can find this _aTypes array for unicode is in 2 headers, but i believe thoses were only relevant when compiling the library, and are not used when using the library.
      I don't need bidirectional support, so i would like to disable it. 60kB difference is the difference between being able to fit the program in memory or not.
      Alexis Marquet
    • Appwizard V1.00_6.10f, headers from this version and lib is M7F version. Hardware is LPC54608 dev board. code still fits because it has 512 KB of flash ROM, but end device is LPL54607 which only has 256KB, which won't fit.
      The problem is that even with BIDI disabled (so there is no call to Enable_bidi in the init), the array of the unicode codepoints is still linked
      Alexis Marquet
    • Thank you very much, that version was not yet available on NXP's website. using v6.14a fixed that, unicode array is no longer linked.
      however, even if i am not using JPEG images, i still get the GUI_JPEG__DecodeLine function and other jpeg routines, same for SPRITE support and so on. Is that a limitation on Appwizard with external resources (on SD card) where it still links those functions because the resources type is not known to APPW? or is that also something that could be "fixed" in the near future?
      Thanks again for your support,
      Alexis Marquet
      I'm happy to hear that it works for you now.
      These functions must be linked since the user can still use JPEGs in their user code, e.g. set a JPEG to an IMAGE object.
      Florian
