J-Link Reset issues
  • J-Link Reset issues
    I am using the J-Link EDU unit with IAR 6.1 to develop code for an At91SAM7 microcontroller and I have some questions regarding hardware resets. My understanding of the J-Link is that RESET pin (pin 15) of the JTAG can be used to force a reset of the processor by being pulled low. I have a logic analyzer set up to monitor the reset line but I have not been able to find a way using the IAR embedded workbench reset command to toggle the line. I have tried several of the reset strategies provided in the setup options but have not found a way to make it work. So my questions are:
    1. Is what I am trying to do possible?
    2. If it is, does anyone have any things to try
    3. Is there a recommended macro file to use with IAR and the J-Link
    Thank you for your help.
    Keith
  • Hello Keith,
    What exactly do you mean here.
    Are you talking about the time when the debug session is started?
    At this time, a toggle of the reset line should be possible when selecting the reset strategy "halt using breakpoint" or "halt at 0"
    To get the reset button in IAR EWARM performing a toggle of the reset line, the following lines should be added to the macro file:
    execUserReset() {
    __message "execUserReset()";
    __hwResetWithStrategy(0, 1);
    Please note that the recommended reset strategy for Atmel SAM7 is reset strategy 0,
    since then J-Link auto-detects what is the best for the device and on the Atmel SAM7
    this is a reset of the peripherals by writing the RSTC_CR register.
    On the Atmel SAM7S by default the reset pin does not have any effect. It has to be enabled via software first.
