[SOLVED] Unable to use RTT with J-Scope on Cypress PSOC4
  • Unable to use RTT with J-Scope on Cypress PSOC4
    I'm trying to use J-Scope to instrument data on a Cypress PSOC4 device (CY8C425, segger.com/evaluate-our-softwa…r/psoc-4-development-kit/). HSS method in Ozone works fine and I was trying out the RTT method using J-scope. I'm not able to use the 3 phase sine example included in the J-Scope installation due to limited RAM in the micro-controller I'm using the most basic function (attached) to check how this RTT would work.
    So far I'm not having any luck. I can see the control block and data format are correctly identified but no data is coming through. Can someone take a look at the code I have and try to see it works on their end?
    John
  • [SOLVED] Unable to use RTT with J-Scope on Cypress PSOC4
    C Source Code: Jscope_RTT_test
    1. #include <project.h> //Specific to Cypress PSOC devices, only needed for CyDelay() function
    2. #include <stdio.h>
    3. #include "SEGGER_RTT.h"
    4. char JS_RTT_UpBuffer[128];
    5. #pragma pack(push, 1)
    6. struct {
    7. int16_t x;
    8. int16_t y;
    9. int16_t z;
    10. } xcelBuffer;
    11. #pragma pack(pop)
    12. int main(void) {
    13. SEGGER_RTT_ConfigUpBuffer(1, "JScope_I2I2I2", &JS_RTT_UpBuffer[0], sizeof(JS_RTT_UpBuffer), SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL);
    14. do {
    15. SEGGER_RTT_Write(1, &xcelBuffer, sizeof(xcelBuffer));
    16. xcelBuffer.x ++;
    17. xcelBuffer.y ++;
    18. xcelBuffer.z ++; //let it overflow for testing
    19. CyDelay(10); //use your own delay funciton, delay 10ms
    20. } while (1);
    21. }
  • Hi John,
    We received you inquiry in our ticket system.
    The engineer responsible for J-Scope will answer you there.
    To keep information to one channel and to prevent additional work load, we will consider this thread as closed now.
