if I set up RTT Viewer with a specific address for the _SEGGER_RTT control block the communication works while debugging with IAR EWARM. If I press the target reset button or redownload in EWARM the output in Terminal shows that it is connected to the exisiting Debug Session but the debug messages sent from target are not displayed in terminal until I disconnect and connect again.
The output after a successfull connection to the existing Debug Session is
Do you have any idea what the problem might be?
Kind regards,
Stefan
J-Link V6.70c - Real time terminal output
SEGGER J-Link ARM V9.1, SN=...........
(I removed the serial number)Process: IarIdePm.exe
Kind regards,
Stefan
