Sitronix ST7789V graphics controller through SPI.
    • Sitronix ST7789V graphics controller through SPI.
      Back on Feb. t, 2019 gtoner asked about using SPI bus to interface with an ili9341 graphics chip. I am trying to do the same thing but with a Sitronix ST7789V graphics controller chip. Sven replied that it was relatively easy, all you had to do was implement SPI versions for the following functions:
      pfWrite8_A0
      pfWrite8_A1
      pfWriteM8_A1
      pfRead8_A1
      pfReadM8_A1
      I am just a tad confused, though. There are a lot more functions like these in the GUI_PORT_API structure. Do I ONLY have to implement these, or do I really need to provide an SPI version for EVERY function listed in the GUI_PORT_API structure?
      Ed H.
      it depends on the interface type. The functions you have listed are sending only 8 bits at once. Other interface may send 16 or 32 bits at once and would have to implement and set the other function pointers.
    • You said "It depends on the interface type". I do not understand this comment. It is the same interface type as the ili9341 IC - an SPI interface. So again, for an SPI interface, do I only have to implement the 8-bit functions you first mentioned, or also the 16 and 32 bit versions?
      Thanks again,
      Ed H.
