Embos V3.50 Iar compiler V3.20 and
Let me describe the context : I have a radio communication with another
equipment that gives me CLOCK using the NMI, and DATA through the P5_7
port.
__regbank_interrupt void __NMI_handler( void )[/b]
rcBitArray[ rcBitCounter-- ] = P5_bit.P5_7;
The use of this NMI is essential, because I have to read the radio frames immediately when they are available.
I have also to manage a communication via Uart4 to a PC :
#pragma vector=(UART4_RX)
__interrupt void Atlas::ISR_S4_Rx( void )
OS_EnterInterrupt();
volatile Int16T rxWord = C_Uart::GetReceivedCharU4();
.......elab.....
OS_LeaveInterrupt();
The problem is that I see the micro stopping to communicate, after some minutes with the PC linked to the uart, and various errors of the OS, such as sometimes, OS_ERR_DICNT, OS_ERR_INV_TASK, OS_LEAVE_INT
I think the problems is related to the use of NMI in this context, cause if I don't use it I don't see any problem
May you help me ?
port.
.......elab.....
May you help me ?
