[SOLVED] Simple project using libopencm3 in SES
  • [SOLVED] Simple project using libopencm3 in SES
    I'm trying to build a simple blinker hello world project using libopencm3. It is a big complicated project and it's using Makefile to build. So far I tried compiling it with SEGGER compiler as CC parameter for the Makefile and creating a Library project in SES importing all the code that I need, but couldn't get it built.
    My target microcontroller is STM32F103C8T6 and the code is based on this example:
    C Source Code: main.c
    1. #include <libopencm3/stm32/rcc.h>
    2. #include <libopencm3/stm32/gpio.h>
    3. static void gpio_setup() {
    4. rcc_periph_clock_enable(RCC_GPIOC);
    5. gpio_set_mode(GPIOC, GPIO_MODE_OUTPUT_2_MHZ,
    6. GPIO_CNF_OUTPUT_PUSHPULL, GPIO12);
    7. }
    8. int main() {
    9. gpio_setup();
    10. while (1) {
    11. gpio_toggle(GPIOC, GPIO12);
    12. for (int i = 0; i < 800000; i++)
    13. __asm__("nop");
    14. }
    15. return 0;
    16. }
    What would be the correct approach to compile this in SES using libopencm3?
    I thought Segger just uses the GCC Compiler ?
    Are you familiar with working on big complicated tools with other IDEs ?
    Have you been able to build simple projects using SES ?
    It's always best to start with simple projects to learn how to use a new tool ...
    What problem(s) did you have?
    It's hard to help you solve the problems when you don't say what those problems are!
  • Sorry for late reply, I have successfully built libopencm3. Here is my solution (it's not perfect, but it seems to work):
    XML Source Code: libopencm3.emProject
    1. <!DOCTYPE CrossStudio_Project_File>
    2. <solution Name="libopencm3" target="8" version="2">
    3. <project Name="libopencm3">
    4. <configuration
    5. Name="Common"
    6. arm_core_type="Cortex-M3"
    7. project_directory=""
    8. project_type="Library" />
    9. <configuration
    10. Name="Debug"
    11. c_preprocessor_definitions="STM32F1"
    12. c_user_include_directories="include" />
    13. <folder Name="lib">
    14. <folder Name="cm3">
    15. <file file_name="lib/cm3/assert.c" />
    16. <file file_name="lib/cm3/dwt.c" />
    17. <file file_name="lib/cm3/nvic.c" />
    18. <file file_name="lib/cm3/scb.c" />
    19. <file file_name="lib/cm3/sync.c" />
    20. <file file_name="lib/cm3/systick.c" />
    21. <file file_name="lib/cm3/vector.c" />
    22. </folder>
    23. <folder Name="stm32">
    24. <folder Name="f1">
    25. <file file_name="lib/stm32/f1/adc.c" />
    26. <file file_name="lib/stm32/f1/flash.c" />
    27. <file file_name="lib/stm32/f1/gpio.c" />
    28. <file file_name="lib/stm32/f1/rcc.c" />
    29. <file file_name="lib/stm32/f1/rtc.c" />
    30. <file file_name="lib/stm32/f1/timer.c" />
    31. </folder>
    32. <folder Name="common">
    33. <file file_name="lib/stm32/common/adc_common_v1.c" />
    34. <file file_name="lib/stm32/common/crc_common_all.c" />
    35. <file file_name="lib/stm32/common/dac_common_all.c" />
    36. <file file_name="lib/stm32/common/dma_common_l1f013.c" />
    37. <file file_name="lib/stm32/common/exti_common_all.c" />
    38. <file file_name="lib/stm32/common/flash_common_all.c" />
    39. <file file_name="lib/stm32/common/flash_common_f01.c" />
    40. <file file_name="lib/stm32/common/flash_common_f.c" />
    41. <file file_name="lib/stm32/common/gpio_common_all.c" />
    42. <file file_name="lib/stm32/common/i2c_common_v1.c" />
    43. <file file_name="lib/stm32/common/iwdg_common_all.c" />
    44. <file file_name="lib/stm32/common/pwr_common_v1.c" />
    45. <file file_name="lib/stm32/common/rcc_common_all.c" />
    46. <file file_name="lib/stm32/common/spi_common_all.c" />
    47. <file file_name="lib/stm32/common/spi_common_v1.c" />
    48. <file file_name="lib/stm32/common/st_usbfs_core.c" />
    49. <file file_name="lib/stm32/common/timer_common_all.c" />
    50. <file file_name="lib/stm32/common/usart_common_all.c" />
    51. <file file_name="lib/stm32/common/usart_common_f124.c" />
    52. </folder>
    53. <file file_name="lib/stm32/can.c" />
    54. <file file_name="lib/stm32/desig.c" />
    55. <file file_name="lib/stm32/st_usbfs_v1.c" />
    56. </folder>
    57. <folder Name="ethernet">
    58. <file file_name="lib/ethernet/mac.c" />
    59. <file file_name="lib/ethernet/phy.c" />
    60. <file file_name="lib/ethernet/phy_ksz80x1.c" />
    61. <file file_name="lib/ethernet/mac_stm32fxx7.c" />
    62. </folder>
    63. <folder Name="usb">
    64. <file file_name="lib/usb/usb.c" />
    65. <file file_name="lib/usb/usb_control.c" />
    66. <file file_name="lib/usb/usb_dwc_common.c" />
    67. <file file_name="lib/usb/usb_f107.c" />
    68. <file file_name="lib/usb/usb_msc.c" />
    69. <file file_name="lib/usb/usb_standard.c" />
    70. </folder>
    71. </folder>
    72. </project>
    73. <configuration
    74. Name="Debug"
    75. c_preprocessor_definitions="DEBUG"
    76. gcc_debugging_level="Level 3"
    77. gcc_optimization_level="None" />
    78. <configuration
    79. Name="Release"
    80. c_preprocessor_definitions="NDEBUG"
    81. gcc_debugging_level="None"
    82. gcc_omit_frame_pointer="Yes"
    83. gcc_optimization_level="Level 1" />
    84. </solution>
    It only works for STM32F1 now and needs to be modified to build for other targets.
    SES comes bundled with both GCC and Clang, but as far as I know it doesn't provide GCC-compatible frontend. gcc/arm-none-eabi/bin/cc1 is indeed GNU C17 (GCC) version 8.3.1 20190703 (release) [gcc-8-branch revision 273027] (arm-none-eabi), but bin/cc is SEGGER's own interface for it: SEGGER Embedded Studio for ARM cc - Release 4.30b.
    Other IDEs I used supported Makefiles, so no problems there.
    I can blink my LED by manipulating the registers directly, but with libopencm3 it's just so much more convenient.
    I had had several problems unrelated to each other, but all solved now. My question was more of a request for a working solution to build the library than a request to solve individual problems for me. So I'm publishing my solution here and hope someone might find it useful.
    Great to hear that you found a solution to implement the library in your project.
    For completion for other users that stumble upon this thread, Embedded Studio comes with a CPU support package manager that uses CMSIS packages from silicon vendors so when starting with a CPU you do not have to do everything from scratch.
    More information about this can be found here:
    segger.com/products/developmen…o/technology/cpu-support/
    There are currently over 3000 devices available via the package manager.
    Via the same package manager you also gain access to our Embedded Studio PRO packages that offer already finished BSP projects for different boards that come with sample projects for nearly all of SEGGERs embedded software solutions:
    segger.com/products/developmen…io/editions/pro-cortex-m/
    So if your board is upon these packages seting and clearing an LED is a simple as calling:
    BSP_SetLED(0) or BSP_ClearLED(0).
    These projects run with our RTOS embOS which also offers numerous start projects for different boards that uses a timer, multi-tasking and easy LED setting:
    segger.com/products/rtos/embos…cortex-m-embedded-studio/
