[ABANDONED] J-Link on-board debugger does not work with SES
  • [ABANDONED] J-Link on-board debugger does not work with SES
    I try to use the on-board ST-Link to work as J-Link Debugger at NUCLEO-STM32L432KC board.
    I followed the instructions in the Converting_Guide and everythink seems to work.
    I used the J-Link Commander to verify the conversion process (for me it looks pretty good :) ).
    Then I programmed my device with J-Flash Lite without any problems :) .
    Now, I tried to debug a small sample project with SEGGER's embedded Studio.
    But immediately after I try to "Start Execution" I get the following error message.
    I also stored the J-Link log file (please see attachments).
    There are listed the following errors.
    Brainfuck Source Code: LOG.txt
    1. ***** Error:
    2. T347C 001:168.980 Programming failed @ address 0x08004808 (program error)
    3. T347C 001:169.052 -- End of flash programming
    4. T347C 001:169.124 -- Start of restoring
    5. T347C 001:169.194 -- Restoring RAMCode
    6. T347C 001:176.427 -- Restore target
    7. T347C 001:176.541 -- Restore memory
    8. T347C 001:176.613 -- Restoring CPU registers
    9. T347C 001:176.716 -- End of restoring
    10. T347C 001:176.793 Restarting due to program error (possibly skipped erasure of half-way erased sector).
    11. T347C 001:176.840 Skip optimizations disabled for second try.
    12. T347C 001:176.888 -- --------------------------------------
    13. T347C 001:177.987 - 304.390ms returns -3
    14. T347C 001:272.209 JLINK_IsOpen()
    15. T347C 001:272.242 - 0.037ms returns 0x01
    16. T347C 001:286.341 JLINK_Close()
    17. T347C 001:286.706 -- CPU_ReadMem(4 bytes @ 0xE0001000)
    18. T347C 001:301.497 - 15.175ms
    19. T347C 001:301.522
    20. T347C 001:301.532 Closed
    Here are my J-Link options.
    After that, I tried to use the on-board J-Link to debug a CubeIDE Eclipse Project. This works without any problems. So It seems to be an SES option issue for me.
    Best Regards!
    • LOG.txt
      (17.53 kB, downloaded 398 times, last: )
    The post was edited 2 times, last by ecom ().
    We gave it a quick try and everything is working fine on our side with the NUCLEO-STM32L432KC.
    Please find the test Project we used attached.
    Could you please try it with that one and check if it works?
  • Hello Fabian,
    Thanks for your reply! I got the same error with your test code.
    BUT: When I reset the device (via reset button at eval board) while programming, it seems to work after a few tries... ?(
    The curious thing is, that this behavior appeared with three different boards... After the board works one time, it always works without any troubles. How can it be?
    This sounds like the problem is somehow connected to the applications you are loading to the device.
    Could you provide us with a sample project to reproduce this?
