I am using NXP’s MCUXpresso with a Segger Flasher ARM. The device is NXP's QN9080.
The built-in FLASH erase & download support for the QN9080C seems to require that an external crystal is present on the device in addition to the internal oscillator. However I am actually using an external TXCO powered from a GPIO pin on the device. Now, I can power the TXCO externally to get my development rolling, but it would be useful to be able to run a little code (using the internal osc.) to configure the GPIO pin to power the TXCO prior to erasing or programming.
The Open Flashloader mechanism would seem to be the place to do this. I have had partial success in following the detailed instructions in the Segger Wiki at wiki.segger.com/Open_Flashloader
I am configuring and driving the appropriate GPIO pin in my Init(), and also disabling the watchdog there.
My Init(), UnInit(), EraseSector() and ProgramPage() implementations all output a pattern on a GPIO pin so that I can unequivocally identify when they run.
I have built and debugged my ELF file and modified the XML file as instructed in the wiki. So far so good…
In MCUXpressso, The following three functions DO actually seem to work:
GUI Flash Tool / Segger J-Link probes / Erase / Enable Erase All Flash Banks
GUI Flash Tool / Segger J-Link probes / Erase / Erase (without Enable Erase All Flash Banks)
GUI Flash Tool / Segger J-Link probes / Program
… but only the FIRST one shows any evidence of my Flashloader ELF code actually running (Init, EraseSector, UnInit all run, in that order).
This is an issue because, without Init(), powering the oscillator and disabling the watchdog does not happen
So it seems to me that, for some reason, there are functions other than those mentioned in the wiki that need to be implemented. Can anyone shed any light on this situation, please?
