I am using the 2456R eval board of renesas for GUI development. I am also using the Touch screen for that but facing issue when I am trying to use the working driver with the eval board code. The Driver is working as standalone but when it is integrated with Segger OS and Win then it gives the interrupt at OS_Createtask as
/* vector 5 TRACE */
__interrupt(vect=5) void INT_TRACE(void) {while (1); }
This interrupt is generated at OS_Disableinterrupt which is called from CreateTask. I am using Segger OS so you can look at this in your code.
Can you help me out. for what can be possible problem
Satyajit
Satyajit
![:(](https://forum.segger.com/wcf/images/smilies/sad.png)
The post was edited 2 times, last by satyajg ().
