[SOLVED]howto remote debugging arm with gdb jlink sam-ice
  • [SOLVED]howto remote debugging arm with gdb jlink sam-ice
    i downloaded a bootstrap and a binary from atmels sampels (AT91SAM9RLEK - getting started) to my board which works.
    To debug:
    i run the segger gdbserver which is running at localhost:2331
    then i open a console and write
    arm-none-eabi-gdb
    <gdb> target remote localhost:2331
    Connected to 127.0.0.1
    SAM-ICE found !
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0xE59FF05C)
    Remote debugging using localhost:2331
    0x00000000 in ?? ()
    <gdb> break main
    No symbol table is loaded use the file command.
    Make breakpoint pending on future shared library load? n
    <gdb> continue
    continuing
    Starting target CPU...
    and nothing happens.
    what´s the error?
    regards
    edit:
    ok fixed it by using the elf file with the file command
    The post was edited 2 times, last by Gobliins ().
    to get an idea what is necessary to setup a debug session with GDB,
    you should refer to the GDB sample projects which come with the J-Link software and documentation package.
    The GDB sample projects are located at $JLINK_INST_DIR$\Samples\GDB\Projects.
    Every project comes with a GDBInit file (*.gdb) which is located in the "Setup" folder of the project.
    The GDBinit files contain all necessary steps to setup GDB for the debug session.
