J-Link loadbin errors - totally at a loss!
  • J-Link loadbin errors - totally at a loss!
    Warning - I'm just starting to work with the cortex-m3 (using a STM32F103VC) and am going crazy! I've been trying to download files from a Yagarto environment into a STM32 Development board with no success. I am able to compile and run the code on the board via the GDB and the J-Link EDU device. The next step was downloading code - no go. I decided to take a step back and see if I could even read/write memory. I used a "savebin foo 0x0, 0x3ffff" command (the entire 256k Flash memory) and that worked fine. I tried writing a main.bin file to the device and that's where the problems started:
    -1-
    Sometimes the J-Link device hangs (com problems, can't allocate memory - yes I reloaded the software and USB driver - no help)
    -2-
    I then read about the J-Linkstm32 Software and gave it a try - I was sort of able to upload data using J-Link afterwards. "Sort of" since the binary data in the main.bin isn't what I see in the processor memory. It has changed though. The J-Link device hangs again from time to time though.
    -3-
    I tried using J-Flash, thinking that I should use that to write the internal Flash. No-go: no Flashable memory found! Is it looking for external memory?
    Am I just missing a major concept regarding the STM32 and/or J-Link??? Do I have a defective device? I'm totally lost Help, please!
    Best Regards,
    confused in Mannheim
    >>-1-
    Could you please specify this a bit more? We have never seen such a behavior in J-Link Commander when using the "loadbin" command
    >>-3-
    You used the Default.jflash J-Flash project, correct?
    When setting up a new J-Flash project, by default it searches for external CFI compliant flash memory.
    But J-Flash comes with a pre-configured Project for the STM32F103RB + internal flash which can easily ported to the STM32F103VC.
    Simply Click "File->Open project", by default it is already pointing to the folder where the
    sample projects are located (If not, you can always find them at $J_FLASH_INST_DIR$\Samples\JFlash\ProjectFiles).
    Open STM32F103RB.jflash and select the STM32F103VC instead of the RB.
    Regarding 1 & 2: What exactly are you trying to do? In your explanation you switched between Eclipse/GDB,
    J-Link commander and J-Flash, so I am not sure what exactly you are trying to do.
