Connecting J-Link to an ARM11
  • Connecting J-Link to an ARM11
    I'm trying to connect the J-Link through JFlashARM to an ARM1176. At this point I'm just trying to establish initial JTAG communication, but it does not appear to work.
    The JLinkARM.log produces the following output:
    T22B4 017:452 SEGGER J-Link V4.14i Log File (0001ms, 0000ms total)
    T22B4 017:452 DLL Compiled: Aug 12 2010 20:19:20 (0001ms, 0000ms total)
    T22B4 017:452 Logging started @ 2010-09-07 13:24 (0001ms, 0000ms total)
    T22B4 017:459 JLINK_SelectUSB(Port = 0) returns 0x00 (0010ms, 0001ms total)
    T22B4 017:469 JLINK_OpenEx(...)
    Firmware: J-Link ARM V8 compiled Aug 12 2010 19:35:38
    Hardware: V8.00
    S/N: 58001208 returns O.K. (0212ms, 0011ms total)
    T22B4 017:681 JLINK_TIF_Select(JLINKARM_TIF_JTAG) returns 0x00 (0000ms, 0223ms total)
    T22B4 017:683 JLINK_CORE_Select(201326591) (0037ms, 0223ms total)
    T22B4 017:731 JLINK_ConfigJTAG(IRPre = 0, DRPre = 0) (0000ms, 0261ms total)
    T22B4 017:731 JLINK_SetEndian(ARM_ENDIAN_LITTLE) returns 0x00 (0001ms, 0261ms total)
    T22B4 017:732 JLINK_GetFirmwareString(...) (0000ms, 0262ms total)
    T22B4 017:741 JLINK_SetSpeed(5) (0002ms, 0262ms total)
    T22B4 017:743 JLINK_GetSpeed() returns 0x05 (0000ms, 0264ms total)
    T22B4 017:761 JLINK_SetResetType(JLINKARM_RESET_TYPE_NORMAL) returns JLINKARM_RESET_TYPE_NORMAL (0000ms, 0264ms total)
    T22B4 017:761 JLINK_SetResetDelay(0) (0000ms, 0264ms total)
    T22B4 017:761 JLINK_ResetPullsRESET(ON) (0000ms, 0264ms total)
    T22B4 017:761 JLINK_Reset() >0x2F8 JTAG>TotalIRLen = 4, IRPrint = 0x01 >0x30 JTAG> >0x210 JTAG> >0xF8 JTAG> >0x90 JTAG>Identified core does not match configuration. (Found: Cortex-R4, Configured: ARM11) >0x30 JTAG> >0x98 JTAG> >0xB0 JTAG>ARM AP[0]: 0x24770001, AHB-AP >0xB0 JTAG>ARM AP[1]: 0x14770002, APB-AP >0xB0 JTAG>ARM AP[2]: 0x14760010, JTAG-AP >0xB0 JTAG> >0xE8 JTAG> >0x278 JTAG> >0x180 JTAG> >0x278 JTAG> >0x330 JTAG> >0x180 JTAG> >0x278 JTAG> >0x330 JTAG> >0x180 JTAG> >0x278 JTAG> >0x330 JTAG>
    >0x180 JTAG> >0x278 JTAG> >0x330 JTAG> >0x180 JTAG> >0x278 JTAG> >0x330 JTAG> >0x180 JTAG> >0x158 JTAG>1 code breakpoints, 1 data breakpoints >0x158 JTAG> >0x1F0 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x1F0 JTAG> >0x1F0 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG>
    >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG>
    ***** Error: Failed to halt CPUData endian: little >0x690 JTAG>Main ID register: 0x00000000 >0x690 JTAG>Cache Type register: 0x00000000 >0x690 JTAG>TCM Type register: 0x00000000 >0x690 JTAG>
    MPU Type register: 0x00000000 >0x690 JTAG>System control register: Instruction endian: little Level-1 instruction cache disabled Level-1 data cache disabled MPU disabled Branch prediction not supported >0x1728 JTAG> >0x1F0 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG>
    >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> >0x158 JTAG> (12605ms, 0264ms total)
    T22B4 030:367 JLINK_Close() (0268ms, 12869ms total)
    From the log it looks like the J-Link is not able to identify the ARM11, it claims that it sees a Cortex-R4 but I'm guessing that this is just the last device in the list?
    Any help would be greatly appreciated.
  • Hi Ossian,
    for checking the initial / basic communication of J-Link + device, J-Link commander should be used.
    What about J-Link commander? Is it able to detect the device correctly?
  • JLink commander output
    H Alex,
    The following is the output from JLink Commander:
    SEGGER J-Link Commander V4.14i ('?' for help)
    Compiled Aug 12 2010 20:19:35
    DLL version V4.14i, compiled Aug 12 2010 20:19:20
    Hardware: V8.00
    S/N : 58001208
    VTarget = 1.747V
    Info: ARM AP[0]: 0x24770001, AHB-AP
    Info: ARM AP[1]: 0x14770002, APB-AP
    Info: ARM AP[2]: 0x14760010, JTAG-AP
    Info: 1 code breakpoints, 1 data breakpoints
    Info: Data endian: little
    Info: Main ID register: 0x00000000
    Info: Cache Type register: 0x00000000
    Info: TCM Type register: 0x00000000
    Info: MPU Type register: 0x00000000
    Info: System control register:
    Info: Instruction endian: little
    Info: Level-1 instruction cache disabled
    Info: Level-1 data cache disabled
    Info: MPU disabled
    Info: Branch prediction not supported
    ****** Error: Failed to halt CPU
    No devices found on JTAG chain. Trying to find device on SWD.
    WARNING: No matching core found. Selecting default core (Cortex-M3).
    ****** Error: Parity error (Data = 0xFFFFFFFF, ReceivedParity = 1)
    No device found on SWD.
    Cortex-M3 identified.
    JTAG speed: 100 kHz
    It does not look like J-Link Commander is able to identify the device fully?
    Ossian
  • More experimentation but still no luck
    Using a simple Default.JLinkScript with CPU=arm1176jfs;
    J-Link commander produces the following output:
    Hardware: V8.00
    S/N : 58001208
    VTarget = 1.753V
    Found 1 JTAG device, Total IRLen = 5:
    ARM11 identified.
    JTAG speed: 100 kHz
    Although it looks like J-Link Commander accepts the provided identification, I'm still not able to halt the cpu or query the registers?
    Calling halt (h) produces the following output:
    J-Link>h
    ****** Error: Can not read register 8 (CPSR) while CPU is running
    ****** Error: Can not read register 9 (R15 (PC)) while CPU is running
    PC: (R15) = 00000000, CPSR = 00000000 (Unknown mode, ARM)
    ****** Error: Can not read register 7 (R7) while CPU is running
    ****** Error: Can not read register 6 (R6) while CPU is running
    ****** Error: Can not read register 5 (R5) while CPU is running
    ****** Error: Can not read register 4 (R4) while CPU is running
    ****** Error: Can not read register 3 (R3) while CPU is running
    ****** Error: Can not read register 2 (R2) while CPU is running
    ****** Error: Can not read register 1 (R1) while CPU is running
    ****** Error: Can not read register 0 (R0) while CPU is running
    R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    ****** Error: Can not read register 14 (R12_USR) while CPU is running
    ****** Error: Can not read register 13 (R11_USR) while CPU is running
    ****** Error: Can not read register 12 (R10_USR) while CPU is running
    ****** Error: Can not read register 11 (R9_USR) while CPU is running
    ****** Error: Can not read register 10 (R8_USR) while CPU is running
    USR: R8 =00000000, R9 =00000000, R10=00000000, R11 =00000000, R12 =00000000
    ****** Error: Can not read register 16 (R14_USR) while CPU is running
    ****** Error: Can not read register 15 (R13_USR) while CPU is running
    R13=00000000, R14=00000000
    ****** Error: Can not read register 22 (R12_FIQ) while CPU is running
    ****** Error: Can not read register 21 (R11_FIQ) while CPU is running
    ****** Error: Can not read register 20 (R10_FIQ) while CPU is running
    ****** Error: Can not read register 19 (R9_FIQ) while CPU is running
    ****** Error: Can not read register 18 (R8_FIQ) while CPU is running
    FIQ: R8 =00000000, R9 =00000000, R10=00000000, R11 =00000000, R12 =00000000
    ****** Error: Can not read register 17 (SPSR_FIQ) while CPU is running
    ****** Error: Can not read register 24 (R14_FIQ) while CPU is running
    ****** Error: Can not read register 23 (R13_FIQ) while CPU is running
    R13=00000000, R14=00000000, SPSR=00000000
    ****** Error: Can not read register 25 (SPSR_SVC) while CPU is running
    ****** Error: Can not read register 27 (R14_SVC) while CPU is running
    ****** Error: Can not read register 26 (R13_SVC) while CPU is running
    SVC: R13=00000000, R14=00000000, SPSR=00000000
    ****** Error: Can not read register 28 (SPSR_ABT) while CPU is running
    ****** Error: Can not read register 30 (R14_ABT) while CPU is running
    ****** Error: Can not read register 29 (R13_ABT) while CPU is running
    ABT: R13=00000000, R14=00000000, SPSR=00000000
    ****** Error: Can not read register 31 (SPSR_IRQ) while CPU is running
    ****** Error: Can not read register 33 (R14_IRQ) while CPU is running
    ****** Error: Can not read register 32 (R13_IRQ) while CPU is running
    IRQ: R13=00000000, R14=00000000, SPSR=00000000
    ****** Error: Can not read register 34 (SPSR_UND) while CPU is running
    ****** Error: Can not read register 36 (R14_UND) while CPU is running
    ****** Error: Can not read register 35 (R13_UND) while CPU is running
    UND: R13=00000000, R14=00000000, SPSR=00000000
    Any ideas what might be the issue? Any advice for what types of commands I might try in the Default.JLinkScript to get things working?
    Ossian
