[SOLVED] Find and Replace - how to trigger replace
  • [SOLVED] Find and Replace - how to trigger replace
    I don't seem to be able to trigger a replace when searching multiple files for and entry. This makes refactoring tedious.
    For example:
    Using the find and replace window, I can set the search for value and set it to search in the "Entire Solution" but the button to "Replace" remains greyed out, even when I double click on the output line within the results box, instead all I get is the searched for word highlighted within the editor window which I then have to edit the manually.
    Is it possible to set this to automatically enable the "Replace" button once I've doubled clicked a result line?
    Currently it is only possible to replace in the currently open files or the open file directly.
    On project or solution level it is not enabled yet but we are working on it and it should be available soon.
