ICONVIEW defaults
    • ICONVIEW defaults
      the emWin user guide mentions in chapter 19.12.1 some default settings for the ICONVIEW widget, like ICONVIEW_FRAMEY_DEFAULT. However, I couldn't find any of these settings in my STemWin, although they would be useful. The default frame setting is 5 pixels, so I have to set the frame to zero in each ICONVIEW item I am using?
      Jan
      these default settings are in most cases preprocessor settings, which makes it impossible to change them after compiling the emWin library (which is the case with STemWin).
      You could write a owner-draw-function and define the look on your own.
