[SOLVED] Ozone - Program enters inmediately in hardfault handler after program and start debugging
  • [SOLVED] Ozone - Program enters inmediately in hardfault handler after program and start debugging
    Hi everybody!,
    I'm new in this forum and using Segger J-Link (i've a J-Link Mini EDU). I have been using J-Link for programming a LPC4337 via SWD without any trouble, using commands in console (connect, h, loadbin, r, g, etc...).
    Now, i want to perform a debug with Ozone, but when i "download and reset" (and run the code), inmediately the execution of the program enters in hardfault handler. The same happens in another uC, so i suppose that it's not a particular problem of the chip.
    My config:
    Device: LPC4337_M4
    Peripherals: using "LPC43xx_43Sxx.svd" that i found on a NXP forum
    Target interface: SWD
    Speed: 4 MHz
    File: using .elf file.
    Any idea of what is going wrong?
    Thanks in advance!
    Mauro.
    Console output (last command Debug.Halt is done by me):
    1. Debug.Start();
    2. Device "LPC4337_M4" selected.
    3. Found SW-DP with ID 0x2BA01477
    4. Scanning AP map to find all available APs
    5. AP[1]: Stopped AP scan as end of AP map has been reached
    6. AP[0]: AHB-AP (IDR: 0x24770011)
    7. Iterating through AP map to find AHB-AP to use
    8. AP[0]: Core found
    9. AP[0]: AHB-AP ROM base: 0xE00FF000
    10. CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    11. Found Cortex-M4 r0p1, Little endian.
    12. FPUnit: 6 code (BP) slots and 2 literal slots
    13. CoreSight components:
    14. ROMTbl[0] @ E00FF000
    15. ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    16. ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    17. ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    18. ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    19. ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    20. ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    21. J-Link: connected to target device
    22. LPC18xx/43xx reset: Halting CPU before performing reset...
    23. LPC18xx/43xx reset: Halted CPU before reset.
    24. Unknown LPC18xx/43xx bootloader variant. Halting after reset may fail.
    25. Elf.GetBaseAddr();
    26. Target.SetReg ("SP", 0x464C457F);
    27. Target.SetReg ("PC", 0x10101);
    28. J-Link: Flash download: Bank 0 @ 0x1A000000: 1 range affected (32768 bytes)
    29. J-Link: Flash download: Total time needed: 0.728s (Prepare: 0.059s, Compare: 0.009s, Erase: 0.439s, Program: 0.215s, Verify: 0.000s, Restore: 0.004s)
    30. Elf.GetBaseAddr();
    31. Target.SetReg ("SP", 0x464C457F);
    32. Target.SetReg ("PC", 0x10101);
    33. Debug.Halt();
  • Hello Mauro,
    The SP and PC seem to take unexpected values.
    Are you debugging an application with e.g. a bootloader?
    If yes the following changes must be done in Ozone to debug an application using a bootloader:
    wiki.segger.com/SEGGER_Ozone#S…g_session_with_bootloader
  • Hi Mauro,
