[SOLVED] emBuild usage
  • [SOLVED] emBuild usage
    I am using ebmBuild to build my SES project ( integration into CI project ).
    Project is nrf52840 based.
    The artifacts from that build ( app.hex , and s140_nrf52_6.1.0_softdevice.hex ) should be later programmed using nrfgprog utility.
    Do I need to specify a programming flash address when manually programming the hex files ? ( or does the tool finds out where to burn them , if so - how ? )
    Ran
  • Hello Ran,
    Generally addresses for hex files do not need to be passed as hex file contain address information within themselves.
    However the nrfgprog utility is not our software but made by Nordic Semi so we can't comment on the exact parameters that are needed to launch it properly. We suggest contacting Noridc in that regard.
    Anyways to use any external tool after a build you can use the post build command project option in Embedded Studio. There you can specify any CL tool which then will be executed after the build has finished.
    If you use the same emProject file in emBuild later it will executed that same steps as well.
