Hi
I've been profiling various emWin parts of some projects, trying to work out what core function is taking what time. I appear to have a bit of a bottleneck with text and I'm wondering if anyone, including Segger, has any comments on the time taken to draw a character?
I am finding that it is generally taking around 0.2ms/character on a 168MHz STM32F4 (GUICC_M565 -> GUIDRV_LIN_16). Of course, it varies with font,text mode, etc but it is always centreing around 0.2ms/char. I have checked with all my non-GUI tasks disabled and with a single hWin (in addition to HWIN_BKWIN). It is only marginally affected by my config of WM_SetCreateFlags(WM_CF_MEMDEV), WM_MULTIBUF_Enable(1), GUI_EnableAlpha(1). It is only marginally affected by BkColor being solid or transparent, and only marginally affected by the text mode (NORMAL or TRANS).
0.2ms/char is around 80k ops per character. Given the font is around 150px area this is 500 ops per char pixel. Given I am using GUI_TM_HASTRANS and the font-painter will be skipping the vast majority of pixels when painting then it may be 10kops per painted pixel. This seems rather a lot.
My wonders are:
Mark
Code:
My WMX is a wrapper for each hWin object. It catches the main WM _cb and paints the background including background image (if enabled). I use it as my base window class which I inherit down from, adding settings, events handlers, etc. If I do not paint the text in this example the timing for my background tasks is around 10ms. De-commenting the FILLRECT adds about 10ms to the paint() time. My _cb handler includes a trap every 20 paints to I can see paint times. Window refresh is set at 500ms.
My wonders are:
- is if the middleware included with Keil MDK is, in some way, throttled/de-optimized?
- are others getting better draw times? If so, I'll go have a further prod at my code.
- is this just what it is?
Mark
Code:
- static void _paint(WMX* this) {
- GUI_RECT rect = WMX_GetRect(this);
- uint8_t rpt;
- if (!this) return;
- GUI_SetFont(&GUI_Font20B_1);
- GUI_SetColor(GUI_WHITE);
- GUI_SetBkColor(GUI_BLUE);
- GUI_SetTextMode(GUI_TM_TRANS);
- rpt = 50;
- while(rpt--){
- GUI_DispStringAt("hello", 400, 240);
- //GUI_FillRect(10, 10, 70, 70);
- static void _cb(WM_MESSAGE * pMsg) {
- GUI_KEY_STATE* pKeyState;
- WMX_X_HELLOWORLD* this;
- WM_GetUserData(pMsg->hWin, &this, sizeof(WMX*));
- switch (pMsg->MsgId) {
- case WM_POST_PAINT:
- if (WMXPrivate(this)->Profiling.iProfile == 0) {
- WMXPrivate(this)->Profiling.iProfile = 0;
- break;
- case WM_PAINT:
- _paint((WMX*)this);
- break;
