Hallo everyone,
I'm using the stm32f429i-disc1 Board without a RTOS, just a superloop with emWin.
I want to have a main site with a menu. The menu (several buttons) has the origin (0,0).
If you want to try it, you have to set #define NUM_VSCREENS 2 in the LCDConfig.c file.
The second site has the origin (0,320) and the content of the second site depends on which button has been pressed. If there are an EDIT widget a Window with a Numpad will be shown. My Problem is, that I can't edit numbers to the EDIT widget.
I have already seen the WIDGET_Numpad.c example, but it did not helped.
The MainTask() funktion is not called in an infinite loop.
I would be glad, if somebody can help me.
If you need more information, just ask me.
Kind regards, Wladimir
MyProject.zip
MyProject.zip
