[SOLVED] how does 'Project Explorer' -> 'external editor' work ?
  • [SOLVED] how does 'Project Explorer' -> 'external editor' work ?
    Please , I have set :
    Options -> Windows -> Project Explorer -> 'external editor'
    in the SEGGER Embedded Studio,
    to the name of my favorite editor ( emacs / emacsclient on Linux ),
    but how to get the Project Editor / Source browser to use it ?
    I can find no 'open with external editor' option anywhere -
    is there one ? Is it possible to open files in Emacs quickly
    from the IDE somehow ?
    If someone could please point me in the right direction, on this,
    I'd much appreciate it - all the manual / reference says is :
    "External Editor The file name of the application to use as the external Environment/Project Explorer/External text editor Editor – FileName" -
    OK, I add the full path of the external editor here, but I can see how to get
    it invoked to edit a file.
    Can anyone enlighten me ?
    Sorry for this newbie SES user question, but it would
    help alot if the documentation was a bit more complete on this option.
    Thanks & Best Regards,
    Jason
  • Hello Jason,
    It seems that this feature is not documented properly yet, thank you for pointing that out.
    To use that feature you set your favorite editor as you wrote and to use it keep Shift pressed while double clicking a source file in the project explorer.
    Then the file should open in the external editor.
    The documentation will be improved accordingly.
  • Aha, fantastic! Thanks Nino .
    Now if I set the Windows -> Project Explorer -> external editor
    to '/usr/bin/emacsclient', shift+<double-click> DOES open in my
    running emacs.
    Note for future versions:
    It would be nice to be able to pass emacsclient / the external editor
    some command line arguments - you seem to support only a program name ,
    not a program name + command line arguments ?
    Currently no CL support is planned, we will put it on the wishlist for future discussions.
