change an edit box text from another dialog
    • change an edit box text from another dialog
      Hi
      I have made two windows(dialogs) by emwin gui builder in my project, first window has a button and 2nd window has an edit box. i want to change text of edit box of 2nd window when i click on 1st window button directly as follows:
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
      // USER START (Optionally insert code for reacting on notification message)
      // USER END
      sprintf(tstr,"fwin:%ld %ld \n\r",dialogTest,WM_GetDialogItem(dialogTest,(GUI_ID_USER + 0x01)));
      _DBG_(tstr);
      //WM_ShowWindow(dialogTest);
      //WM_Paint(dialogTest);
      EDIT_SetText((EDIT_Handle)WM_GetDialogItem(dialogTest,(GUI_ID_USER + 0x01)),"thats ok");
      break;
      as you can guess (GUI_ID_USER + 0x01) is id of edit box. but calling Edit_SetText() couses a HardFault.
      By the way i know i can change the editbox text in wm_paint message of 2nd window, but i want to know if i can change it directly from another window or not.
      thanks. :)
      The post was edited 1 time, last by mtajian ().
      You can use the IDs of a widget to get its handle and then use the handle to change the widgets properties.
      Please don't use functions like WM_Paint(), better let the Window Manager decide when to redraw a window/widget.
      Every time a window/widget gets invalid (either by changing its properties or by calling WM_InvalidateWindow()) it will get redrawn. The redrawing gets performed the next time GUI_Exec() or GUI_Delay() are getting called. Typically one of these functions are getting called within a 'stay alice loop' in the main function (e.g. in MainTask).
      Here is a short example on how to change the text of an EDIT widget by pressing a BUTTOn in another dialog. Here I get the dialog handle by calling WM_GetNextSibling() with current dialog handle. You could also remember the dialog hanlde in a file-wide static variable.
      1. #include "DIALOG.h"
      3. *
      4. * Externals
      5. *
      7. */
      9. *
      10. * Defines
      11. *
      12. **********************************************************************
      13. */
      14. #define ID_WINDOW_00 (GUI_ID_USER + 0x00)
      15. #define ID_BUTTON_00 (GUI_ID_USER + 0x01)
      16. #define ID_BUTTON_01 (GUI_ID_USER + 0x02)
      17. #define ID_WINDOW_10 (GUI_ID_USER + 0x10)
      18. #define ID_EDIT_10 (GUI_ID_USER + 0x11)
      19. /*********************************************************************
      20. *
      21. * Static data
      22. *
      23. **********************************************************************
      24. */
      25. /*********************************************************************
      26. *
      27. * _aDialogCreate0
      28. */
      29. static const GUI_WIDGET_CREATE_INFO _aDialogCreate0[] = {
      30. { WINDOW_CreateIndirect, "Window", ID_WINDOW_00, 0, 0, 100, 100, 0, 0x0, 0 },
      31. { BUTTON_CreateIndirect, "Text A", ID_BUTTON_00, 10, 15, 80, 20, 0, 0x0, 0 },
      32. { BUTTON_CreateIndirect, "Text B", ID_BUTTON_01, 10, 65, 80, 20, 0, 0x0, 0 },
      33. };
      34. /*********************************************************************
      35. *
      36. * _aDialogCreate1
      37. */
      38. static const GUI_WIDGET_CREATE_INFO _aDialogCreate1[] = {
      39. { WINDOW_CreateIndirect, "Window", ID_WINDOW_10, 110, 0, 100, 100, 0, 0x0, 0 },
      40. { EDIT_CreateIndirect, "Edit", ID_EDIT_10, 10, 40, 80, 20, 0, 0x64, 0 },
      41. };
      42. /*********************************************************************
      43. *
      44. * Static code
      45. *
      46. **********************************************************************
      47. */
      48. /*********************************************************************
      49. *
      50. * _cbDialog0
      51. */
      52. static void _cbDialog0(WM_MESSAGE * pMsg) {
      53. WM_HWIN hItem;
      54. int NCode;
      55. int Id;
      56. switch (pMsg->MsgId) {
      57. case WM_INIT_DIALOG:
      58. //
      59. // Initialization of 'Window'
      60. //
      61. hItem = pMsg->hWin;
      62. WINDOW_SetBkColor(hItem, GUI_MAKE_COLOR(0x00400040));
      63. break;
      64. case WM_NOTIFY_PARENT:
      65. Id = WM_GetId(pMsg->hWinSrc);
      66. NCode = pMsg->Data.v;
      67. switch(Id) {
      68. case ID_BUTTON_00:
      69. switch(NCode) {
      70. case WM_NOTIFICATION_RELEASED:
      71. hItem = WM_GetNextSibling(pMsg->hWin); // Get sibling of this dialog which is the other dialog
      72. hItem = WM_GetDialogItem(hItem, ID_EDIT_10); // Get the handle of the EDIT widget
      73. EDIT_SetText(hItem, "Text A");
      74. break;
      75. }
      76. break;
      77. case ID_BUTTON_01:
      78. switch(NCode) {
      79. case WM_NOTIFICATION_RELEASED:
      80. hItem = WM_GetNextSibling(pMsg->hWin); // Get sibling of this dialog which is the other dialog
      81. hItem = WM_GetDialogItem(hItem, ID_EDIT_10); // Get the handle of the EDIT widget
      82. EDIT_SetText(hItem, "Text B");
      83. break;
      84. }
      85. break;
      86. }
      87. break;
      88. default:
      89. WM_DefaultProc(pMsg);
      90. break;
      91. }
      92. }
      93. /*********************************************************************
      94. *
      95. * _cbDialog1
      96. */
      97. static void _cbDialog1(WM_MESSAGE * pMsg) {
      98. WM_HWIN hItem;
      99. switch (pMsg->MsgId) {
      100. case WM_INIT_DIALOG:
      101. //
      102. // Initialization of 'Window'
      103. //
      104. hItem = pMsg->hWin;
      105. WINDOW_SetBkColor(hItem, GUI_MAKE_COLOR(0x00808040));
      106. //
      107. // Initialization of 'Edit'
      108. //
      109. hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_10);
      110. EDIT_SetText(hItem, "123");
      111. EDIT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
      112. break;
      113. default:
      114. WM_DefaultProc(pMsg);
      115. break;
      116. }
      117. }
      118. /*********************************************************************
      119. *
      120. * _cbBk
      121. */
      122. static void _cbBk(WM_MESSAGE * pMsg) {
      123. switch (pMsg->MsgId) {
      124. case WM_PAINT:
      125. GUI_SetBkColor(GUI_BLACK);
      126. GUI_Clear();
      127. break;
      128. default:
      129. WM_DefaultProc(pMsg);
      130. break;
      131. }
      132. }
      133. /*********************************************************************
      134. *
      135. * Public code
      136. *
      137. **********************************************************************
      138. */
      139. /*********************************************************************
      140. *
      141. * MainTask
      142. */
      143. void MainTask(void) {
      144. GUI_Init();
      145. WM_SetCallback(WM_HBKWIN, _cbBk);
      146. GUI_CreateDialogBox(_aDialogCreate0, GUI_COUNTOF(_aDialogCreate0), _cbDialog0, WM_HBKWIN, 0, 0);
      147. GUI_CreateDialogBox(_aDialogCreate1, GUI_COUNTOF(_aDialogCreate1), _cbDialog1, WM_HBKWIN, 0, 0);
      148. while (1) {
      149. GUI_Delay(100);
      150. }
      151. }
      152. /*************************** End of file ****************************/
