[ABANDONED] Atmel Studio to Embedded Studio (AS7->SES)
  • [ABANDONED] Atmel Studio to Embedded Studio (AS7->SES)
    Hello Forum,
    i have a larger Atmel Start Project for Atmel SAME54 in Atmel Studio 7.
    Is there a way to change with this to embedded studio ?
    There are import functions for IAR and others but nothing for Atmel.
    And is it possible to use a project in embedded studio for linux and windows ?
    The files are the same but the paths names are not the same.
    How can this be handled ?
    Thomas
  • Hello Thomas,
    Currently there is no automated way to import AS7 projects to ES.
    But this can be accomplished manually.
    Embedded Studio is multi-platform software so you can use the same ES project on Linux, Windows and MacOS.
    You can use relative paths to counter this issue.
  • I created a new embedded studio project for my SAME54 target and added the sources from AS7 project.
    After successful compiling the sources without errors and warnings the linker starts.
    Then i got this:
    1> Linking k3.elf
    1> "R:/program-win7-ssd/SEGGER/SEGGER Embedded Studio for ARM 4.10/bin/segger-ld" --add-region FLASH=0x00100000@0x00000000 --add-region RAM=0x00040000@0x20000000 --defsym=__STACKSIZE__=1024 --defsym=__STACKSIZE_PROCESS__=0 --defsym=__HEAPSIZE__=1024 --full-section-headers -ereset_handler --defsym=__vfprintf=__vfprintf_int_nwp --defsym=__vfscanf=__vfscanf_int -v --fatal-warnings -EL -mcpu=cortex-m4 --gc-sections -TR:/k3/SAME54P20A/SES/SEGGER_Flash.icf -Map Output/Debug/Exe/k3.map -u_vectors -o Output/Debug/Exe/k3.elf --emit-relocs --start-group "@R:/k3/SAME54P20A/SES/Output/k3 Debug/Obj/k3.ind" --end-group
    Build failed
    How can the reason be found for such a "build failed" without further hints ?
    Thomas
  • Hello Forum,
    i looked in the details and found that the problem is with the linker named "segger-ld".
    I moved the project to SES in Ubuntu 64Bit and checked there, problem stays the same.
    I copied the linker cmd line to a bash and executed manually in $(ProjectDir).
    The segger-ld smashes a "Speicherzugriffsfehler" what is now visible, but not in the SE output window, why not ?
    I started the same command with a strace in front to see what happens, here the interesting part of output:
    openat(AT_FDCWD, "/usr/share/segger_embedded_studio_for_arm_4.10/lib/libvfscanf_v7em_fpv4_sp_d16_hard_t_le_eabi.o", O_RDONLY) = 3
    fstat(3, {st_mode=S_IFREG|0444, st_size=26536, ...}) = 0
    lseek(3, 24576, SEEK_SET) = 24576
    read(3, "scanf_long_long\0.rel.text.libc._"..., 1960) = 1960
    lseek(3, 0, SEEK_SET) = 0
    brk(0x23bd000) = 0x23bd000
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\1\0(\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 24576) = 24576
    read(3, "scanf_long_long\0.rel.text.libc._"..., 4096) = 1960
    close(3) = 0
    brk(0x23de000) = 0x23de000
    brk(0x23ff000) = 0x23ff000
    brk(0x2420000) = 0x2420000
    --- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=NULL} ---
    +++ killed by SIGSEGV (core dumped) +++
    Speicherzugriffsfehler (Speicherabzug geschrieben)
    Seems that segger-ld behind all project .obj tries at last to read in "libvfscanf_v7em_fpv4_sp_d16_hard_t_le_eabi.o" and dies after that.
    I can't find the "Speicherabzug" where is it written to ?
    Could it be a problem with the large number of source files (97) or something ?
    Thomas
  • Hello Thomas,
    Would it be possible for you to provide us with the project for reproduction purposes so we can investigate this further?
