[SOLVED] Ozone: SWO issues
  • [SOLVED] Ozone: SWO issues
    Hello Nino,
    I noticed another problem:
    The activation of SWO fails at startup. I need to configure it manually. This is the Output I get:
    >> Disabled output of control characters
    >> SWO active
    >> failed to activate SWO data capture: SWO trace cannot be started: invalid core frequency
    >> SWO inactive
    Is it possible to activate SWO when breaking at main() ?
    Kind regards
    Andreas
  • Hello Andreas,
    How are you activating SWO in Ozone? Did you enable it under Tools->Trace Settings->SWO?
    Are CPU and SWO speed selected as auto?
    How are you using SWO in your application? Keep in mind that Ozone currently only supports printf messages over SWO but no trace.
    Trace over SWO will be added at a later point.
  • Hello Nino,
    when I start Ozone, I normally load one of my pre-configured "jdebug" files. SWO is activated in these files. But when start Debugging, it connects to the Target and breaks at "main". Then I see that SWO cannot start.
    I've selected anything as "auto" and I use SWO only for printf now.
    Kind regards
    Andreas
    Which target device are you looking to use SWO on?
    Some require extra init steps. More device specific special cases can be found on our wiki.segger.com website.
  • Hello Andreas,
    Thank you for clarifying.
    The issue was reproducible with the mentioned setup.
    A fix has already been applied and should be available with the enxt Ozone release planned for this week.
    To stay up to date with our releases we recommend subscribing to our notification list: segger.com/notification/subscribe.php?prodid=178,7
  • Hello Andreas,
    The new Ozone version has been released. Could you verify that it is working with your setup as well?
  • Hello Andreas,
