[SOLVED] Ozone: Tooltips are not visible
  • [SOLVED] Ozone: Tooltips are not visible
    I use the newest Ozone from today. If I move the mouse over my code I usually get a Tooltip with a black font. Now its a white font over a bright background, which is not visible anymore.
    I use Ubuntu Mate 16.04 LTS. I got several updates today.
    Do I need to install any package to get a black font? This sounds like a similar issue with GTK <-> KDE.
    Kind regards
    Andreas
    • Screenshot at 2018-10-16 16:42:48.png
    We were able to locate the probable cause of this issue and it should be fixed with the next Ozone release version.
    Could you verify that the latest Ozone release V2.60a fixes the reported issues?
  • Hello Nino,
    thanks for the very fast fix! I can verify that this problem is fixed. Tooltips are readable now.
    I noticed another problem:
    The activation of SWO fails at startup. I need to configure it manually. This is the Output I get:
    >> Disabled output of control characters
    >> SWO active
    >> failed to activate SWO data capture: SWO trace cannot be started: invalid core frequency
    >> SWO inactive
    Is it possible to activate SWO when breaking at main() ?
    Kind regards
    Andreas
  • Hello Andreas,
    Your new question has been split into a new post: Ozone: SWO issues
