Problem with "unsecure" command
  • Problem with "unsecure" command
    Hi!
    I try to unsecure / erase on a chip already programmed and secured (STM32F103RCT6). I have the J-FLASH ARM license. When I execute "UNSECURE" command, I got the following message from the application: "Chip unsecured successfully - Completed after 1.782 sec".
    After, when I try to execute "ERASE CHIP" command, I got the following message from the application: "Failed to erase chip (erase error)". My chip is always secure, even after the "UNSECURE" command...
    If I want to erase my chip memory, I have to execute the JLINKSTM32.EXE program before, since "UNSECURE" command doesn't work at all!
    Do I make something wrong using JFLASHARM.EXE program???
    ___________________________________________________________________
    Secondo, I want to write an automated sequence (batch file) for production process to program our onboard chip. When starting, the application secure the chip memory, so if I want to reprogram the chip I have to unsecure it. My batch file work fine if I call the "JLINKSTM32.EXE" programm before erasing sequence. But user has to click on "OK" button to start programm, then press a key to continue the sequence... I don't want any user interaction during programming sequence...
    If I try the execute the following in my batch file "JFLASHARM.EXE -unsecure -exit", GUI returns "UNSECURE" function is not a valid command!!!
    In both case, unsecure command does not work!!!
    Is it a bug when calling "JFLASHARM.EXE" with "-unsecure" command option????
    Thank for your help
    regarding the "unsecure" command in J-Flash via command line:
    Sorry, there is a typo in the UM08003.
    The commands are "securechip" and "unsecurechip"
    Which version of J-Flash do you use?
    After unsecuring: Can you read back the target memory?
    If not, is it possible to this after a power-on-reset of the device?
  • Hi Alex!
    I'm using JFlashARM included in JLinkARM_V410i (J-FLASH ARM V4.10i, compiled 14:44:49 on Jan 25 2010). I think it's the latest version available on your site.
    After unsecuring, yes I'm able to read the entire chip chip memory, but unable to erase it!!!
    I read in documentation that unsecuring a chip cause a mass erase of the chip. Is that exact?? Because it's not what I see with my board!! If I want to erase a secured chip, I have to execute JLinkSTM32.exe program...
    Sylvain
  • Hi Sylvain,
    The current release version of the J-Link software is V4.14f, the current Beta version is V4.15t.
    Could you please try out the current beta version, since we recently (I think it was V4.15c) fixed
    a problem regarding the unsecure command in combination with the STM32?
    This is correct. Unsecuring a secured device, causes a mass erase.
