[SOLVED]Problem Regarding connection of SAM-ICE with SAM-BA (Atmel AT91 ISP)
  • [SOLVED]Problem Regarding connection of SAM-ICE with SAM-BA (Atmel AT91 ISP)
    Dear Sir
    I am unable to connect my SAM-ICE with SAM-BA atmel ISP for AT91SAM7x Series of microcontrollers
    and even not able to put breakpoint in ISR routine while using SAM-ICE with IAR Compiler
    I had Jlink ARM 4.14 version installed on my PC and SAM-BA AT91 ISP Version 1.13 installed.
    in this case I was able to connect to SAM-BA using SAM-ICE.
    when i updated Jlink ARM 4.14 version from then I am not able to get connection with SAM-BA ISP
    if you want i can explain you problem in detail.
    Pls Reply
    would be very helpful if you explain what exactly the problem is.
    Otherwise it will be really hard to help you here.
    By the way: Is J-Link commander of V4.14 still able to connect to the device?
  • Hi
    1: i was using SAM-ICE with Jlink ARM Ver 3.80b on my PC.i have costomised Target board of AT91SAM7X512
    with this i was able to debug my code properly.
    2:i am having AT91 ISP SAM-BA ver 1.13 installed on my PC.using this i use to download bin file into Flash memory of Target processor.
    3:then i brought new SAM-ICE and connected it to my Target board and used AT91 ISP SAM-BA ver 1.13 for Programming the bin file.
    then for first time connection was successfully made.and then i download the bin file in to Target board.
    4:after this with new SAM-ICE i started debugging my Code in IAR and it gave me a message that New version of Jlink ARM is available do you want to update it i clicked on yes.and after that i started with debugging.and it was working fine.
    5:now again when i tried to connect SAM-ICE to AT91 ISP SAM-BA ver 1.13. i was not able to make a connection.
    so today my problem is that i can debug my code in IAR using SAM-ICE but i cannot Program my Processor using AT91 ISP SAM-BA ver 1.13.
    is there any way i can Reset SAM-ICE to its original Factory settings.
