LISTVIEW add row
    • LISTVIEW add row
      I wonder how LISTVIEW_AddRow() manages memory.
      I can see it is working very well, whoever I have a table of data which I need to display, and this table adds one line per day.
      So when my program runs it loops on all the lines in this table and calls LISTVIEW_AddRow() for each line.
      What is the memory requirements, will my program crash after n days? (if AddRow allocates memory, it will fail some time)
      If yes, how to overcome (user can scroll up or down).
      Johanan
      LISTVIEW_AddRow() allocate a block of memory from the GUI_MEMORY pool (defined by GUI_ALLOC_AssignMemory()). If you pass NULL to the function LISTVIEW_AddRow() it requires at least a few bytes for information about the allocated memory block.
      If you pass some strings to LISTVIEW_AddRow() it will alocated as much memory as required to save the strings.
      If you run out of memory at some point the function LISTVIEW_AddRow() will return with 1 (adding a row failed).
      You can check the return value of LISTVIEW_AddRow() and decide what to do, maybe deleting some of the old rows or writing the content to a file and delete the old rows.
