[SOLVED] J-Link Plus cannot connect to an NXP MIMXRT1052DVL6B
  • [SOLVED] J-Link Plus cannot connect to an NXP MIMXRT1052DVL6B
    I'm using a J-Link Plus as a debugger on a custom board with an NXP MIMXRT1052DVL6B. However the MCUXpresso IDE was unable to connect to the custom board. After searching the Intranet, I have been using J-Link Commander to try and identify the problem. I have upgraded the J-Link to version 6.33i, I have tried different speeds, devices and configurations, but the result is always the same. I have attached a screen capture and the J-Link Commander log.
    Some questions:
    1.) Is the J-Link Commander communicating with the MCU ( the JTAG ID of 0x188C301D is correct for the NXP MIMXRT1052DVL6B )?
    2.) Is there any additional information available from the return code 0xFFFFFEFB that is being returned from the connect call?
    3.) Any known issues with the NXP MIMXRT1052DVL6B?
    We tried to reproduce the issue connecting to a IMXRT1050-EVKB eval board. Attached is the sequence using SWD. JTAG is not supported on that board per default.
    Does connecting to your target device work using SWD instead of JTAG?
    Do you have an eval board with JTAG enabled to test against?
    More information about RT1052 device specifics can be found on our Wiki page: wiki.segger.com/IMXRT105x
