[SOLVED] How can I use emScript to convert hex value to decimal value?
  • [SOLVED] How can I use emScript to convert hex value to decimal value?
    I would like to create a small javascript function to add two hexadecimla numbers. I do know that this is possible in javascript doing
    JavaScript Source Code
    1. var res = parseInt("0x01",16) + parseInt("0x02",16)
    However, when running that in the javascript code within segger I get that the varriable res is undefined and I don't understand why.
    Can someone let me know why is this happening?
    Thanks!
    When using your Code in our emScript example from the Embedded Studio example we get no compile errors.
    studio.segger.com/index.htm?ht…com/emScript_examples.htm
    Edit:
    Great to hear that you are up and running now.
