i added the truetype folder to my stm32f429i_disco project.
But when i call GUI_TTF_CreateFontAA i jump directly to the HardFault_Handler.
The code runs well in simulator.
In the main i have :
GUI_Init();
GUI_Initialized = 1;
/* Initialize RTC and Backup */
RTC_Init();
/* Activate the use of memory device feature */
WM_SetCreateFlags(WM_CF_MEMDEV);
/* Do the calibration if needed */
CALIBRATION_Check();
Then i enter the mainTask
void MainTask(void) {
#ifdef USE_BRUSCHI
_CreateFonts();
#endif
_CreateFonts(); function is the following :
unsigned _aHeight[] = { 16, 20, 32, 48 };
GUI_TTF_CS _aCS;
GUI_FONT _MainTask_Font;
static int _CreateFonts () {
GUI_TTF_DATA TTF_Data;
TTF_Data.pData = &_acBRUSHSCI; // Set pointer to file data
TTF_Data.NumBytes = sizeof(_acBRUSHSCI); // Set size of file
_aCS.PixelHeight = _aHeight[2];
_aCS.pTTF = &TTF_Data;
if (GUI_TTF_CreateFontAA(&_MainTask_Font, &_aCS)) {
return 1;
return 0;
_acBRUSHSCI has been generated from emWin tool truetype c converter
const unsigned char _acBRUSHSCI[53456UL + 1] = {
0x00, 0x01, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x80, 0x00, 0x03, 0x00, 0x70, 0x44, 0x53, 0x49, 0x47, 0x12, 0x9C, 0xF7, 0x9D, 0x00, 0x00, 0xBB, 0xD4, 0x00, 0x00, 0x14, 0xFC, 0x4F, 0x53, 0x2F,
Have you any idea of the problem ?
thanks for any support
GUI_Init();
RTC_Init();
#ifdef USE_BRUSCHI
_CreateFonts();
#endif
GUI_TTF_CS _aCS;
return 1;
return 0;
