[SOLVED]CFI not working after unlock sectors
  • [SOLVED]CFI not working after unlock sectors
    I bought two board with an arm7tdi.
    When i started my experiments was possible to read the flash (unsupported) EON EN29LV320AB trought the cfi. When i tried to unlock the
    sectors, just only unlock, some thing gone wrong and the cfi has stopped to work. To be sure about my operations i tried with the second identical board with the same results.
    Now, forcing the setting with a similar memory type and disabling the check on the manufacturer and flash id, i can read the memory. Unfortunately is not possible to unlock and erase the flash to rewrite it.
    I tried to put different flash address in the settings , but no one permit to have the cfi working.
    This is the result with the flash autodetection:
    Connecting ...
    - J-Link firmware: V1.20 (J-Link compiled Feb 20 2006 18:20:20 -- Update --)
    - JTAG speed: 2666 kHz (Auto)
    - Initializing CPU core (Init sequence) ...
    - Executing Reset (0, 0 ms)
    - Initialized successfully
    - J-Link found 1 JTAG device. Core ID: 0x1F0F0F0F (ARM7)
    - Reading CFI info ...
    - Could not find CFI compliant flash device
    - Detecting flash memory ...
    - ERROR: Could not find any flash devices
    - ERROR: Failed to connect
    Any help is appreciate
    Gof.
  • Hi Gof,
    did you ensure that the external bus interface (EBI) of the device you are using, is configured correctly?
    Since, as long as the device is CFI-conform/compatible and the EBI is configured correctly, J-Flash should be able to auto detect the device.
  • After a night with many tests (a real bruteforce), i think to have found a solution.
    When i connect the device, the program will write in the flash/sdram register to init it.
    Now i have :
    - Connecting ...
    - JTAG speed: 5 kHz (Fixed)
    - Executing Write 32bit (0x0D000004, 0x00000073)
    - Executing Write 32bit (0x0D00000C, 0x00000071)
    - Executing Write 32bit (0x0D000008, 0x00000002)
    - Executing Write 32bit (0x0D000010, 0x00000003)
    - Executing Write 32bit (0x0D000014, 0x00000840)
    - Executing Write 32bit (0x0D000020, 0x00000001)
    - Executing Write 32bit (0x0D000018, 0x000000C0)
    - Executing Write 32bit (0x0D000010, 0x00000000)
    - JTAG speed: 1000 kHz (Fixed)
    - Found CFI compliant flash device
    - 2 block regions
    - 8 sectors with 8 KB
    - 63 sectors with 64 KB
    - Flash ID (Chip 0) = 0x7F22F9
    - Matching flash chip found: "Eon EN29LV320AB"
    - CFI info read successfully
    - Connected successfully
    But the strange thing is that in the begining it work without any init.
    Now i have a doubt.... why if i set the physical flash address ( 0x04000000 ) the program say:
    - Flash ID (Chip 0) = 0x19F02860
    - Flash memory detected successfully
    but if i use a different address it found the flash?
    I tried to add my flash in your cvs. Can be good this ?
    Eon;EN29LV320AB;7F22F9;7F00F9;0;1;0;16;1;0;0;0;0;0;0;0;0;0;0;0;0;"2000[8]; 10000[63];"
    ( i tried it and appear to work )
    Many tnx for the nice support.
    Gof.
  • I found the solution to my problems. I lose many days because this china guy are very poor (like my english :P ).
    This board has a little flash encryption. If i not enable a flag , when i read the memory it is broken.
    So, tnx again for the help ;)
    Gof.
