[SOLVED] OZONE FreeRTOS HALT EmptyCallStack when using Float
  • [SOLVED] OZONE FreeRTOS HALT EmptyCallStack when using Float
    I am using OZONE(V2.56i) to debug FreeRTOS on a STM32F437, Compiler GCC (Atollic TrueStudio for STM32 Version: 9.0.0 )
    Starting the Programm In the Ozone-Debugger and Pause it(== crtl+F5), i can see the complete List of all FreeRTOS Tasks
    and by clicking the Task, i see the assoceated CallStack of the Task.
    - OK
    BUG:
    The CallStack of one Task disappeares compleatly after some time (Only a Null- Pointer is shown)
    This happens exactly after the first use of any FLOAT in this Threat - and stays until the next restart of the System.
    Changeing the Code to Integer-Aritmetic (Fixpoint-Integer/ Q31) helps to overcome the Problem - for some time.
    The critical Threat is my GUI-Thread.
    I am using emWin. (ST-library version)
    when opening a Window, that uses a Circle or ARC (In AA-Mode) the problem is back (- no CallStack shown in OZON ) for this thread (after pausing the thread).
    - I suppose there are some trigonometric functions like SIN inside the Draw-Circle(==using floats)
    By elininating the Circles, the OZONE works fine, and i have the CallStack.
    ==> I tried to switch emWin to Software-Floats, but i could not manage.
    INFO:
    When using a Breakpoint in the Thread, the Call-Stack is correct shown - the effect only occurs, when pausing the System in the Ozone-Debugger.
    I need the pause-functionality in Ozone with the Call-Stack, because the Thread hangs some times (Closed-Loop), and i do not know where --> (No Place to set the Breakpoint)
    I would be nice, if i can debug the Threads in Ozone, when Hardware-Supportet Float aritmetic is enabled
    Such an issue is now known to us.
    Could your provide us with a reproduction example project?
    Any STM32F4 eval board as baseboard would suffice.
  • Also reproduceable in Atollic with FreeRTOS --> Seams a Problem of the J-Link FreeRTOS Awarenes
    During preparing an Example for You, i discovered, that it is the same in Atollic-Debugger.
    --> seems to be a Problem with the FreeRTOS awareness of the J-Link, not a Problem of Ozone
    Test-Constellation:
    1) STM32F429I-DISCO, ST-Link changed to "J-Link On Board" with J-Link Reflash utility to enable FreeRTOS-Awareness
    2) CubeMX Project generated Project with 2 aditional Tasks, one calling a Subroutine with a Float
    3) Pressing Pause --> You will get the Pictures in the attachement: The CallStack of myTask02/StartTask02 is empty
    • CubeMX_Main.zip
      (10.45 kB, downloaded 552 times, last: )
    Thank you for providing the example project and reproduction steps.
    With them we were able to reproduce the issue.
    A fix should be available with the next Ozone release version planned next week.
