I use oZone with a J-Trace for ARM Cortex-M on a Nordic nRF52832. When resetting the system, I see different behavior with tracing disabled, also different behavior on first start. It seems oZone just reads the start address from the ELF file and jumps to that address, is that right? Can I change this behavior so that it mimics a true cold reset (through the bootloader, using the MBR etc.)?
[SOLVED] oZone reset behavior
Share
