[SOLVED] iMX6UL - DDR initialization for u-boot
  • [SOLVED] iMX6UL - DDR initialization for u-boot
    I'd like to use a JLink Pro to debug U-boot on the iMX6UL, but DDR needs to be initialized first.
    Does SEGGER provide scripts for initialization of DDR on the iMX6ULEVK platform? Or example scripts for some iMX6 platform that can be tailored for the EVK?
    Otherwise, is there another recommended procedure for loading U-boot via JTAG?
  • I came up with the attached script for JLink.exe. After running the script, it allows writing U-boot to DDR address x87800000 with this command:
    1. loadbin u-boot.bin 87800000
    "verifybin" returns successful.
    But after issuing "go", u-boot isn't working properly (no console output). I assume something is still missing or incorrect from the initialization. In particular I'm not sure about the "wreg r13 93ff20" command. I stole that from another forum post. Any guidance would be appreciated.
    We do not provide example scripts for device specific peripheral or memory initialization.
    As user v01d correctly suggested we recommend contacting NXP in this case.
    We will consider this thread now as solved.
