[ABANDONED] Flasher ARM production supply power on / off ascii command
  • [ABANDONED] Flasher ARM production supply power on / off ascii command
    For my solution I need to power on/off the supply power of the Flasher. In the command list I found only ascii commands for programming, not for controlling the power supply.
    Is it not possible to control the power supply via ascii command?
    Is it possible to call the jflash.exe with parameters from our production program to control the power supply? (I think not)
    Is it possible with the J-Link SDK to control the power supply? (maybe?)
    Are there other solutions?
    Thx
    For clarification, are you talking about the power supply of the Flasher itself or the possibility to supply the target device with power through Pin 19?
    In the latter case you can use J-Link Commander "power on" and "power off" for that.
    More information can be found in the J-Link user manual in section: Target power supply
    The same information can be found in the Flasher manual under the same section.
  • Hallo Nino,
    I am using the Flasher via RS-232 in my production environment (a .Net Application), for me it is important that the .Net application can power on and power off the device target power through Pin 19. I think with J-Link Commander it is not possible to control the process automatically with my .Net application.
    Julian
  • Hello Julian,
    currently it is not implemented to do this by the ASCII command protocol. We could extend the interface to be capable of that. But we do not have concrete schedule for that. Do you have a dead line?
    If you have a J-Link SDK, this can control of the power.
    Michael
