[SOLVED] Breakpoints not saved on Ozone exit ..
  • [SOLVED] Breakpoints not saved on Ozone exit ..
    How do I save all breakpoints I set while using a Project?
    After I exist Ozone, and re-start and reload same project, all break points are gone.
    Is there special way to save them?
    Ozone does not save breakpoints automatically.
    Should you be using always the same ones you can add them to your Ozone project using the jdebug file scripting interface. More information about possible user actions can be found in the Ozone manual in section 7.7.14 Breakpoint Actions.
