[SOLVED] semaphore already created?
  • [SOLVED] semaphore already created?
    is there a way to find out if a semaphore or mailbox is already created?
    like:
    OS_RSEMA* sema = NULL;
    OS_CreateRSema(sema);
    if(sema != NULL){
    printf("sema exists");
    I'm using embOS 3.60d
  • Hi Axel,
    no, there is unfortunately no easy way and I don't think you example will work like that since you have only declared a pointer but not the variable itself.
    Usually it would be something like:
    OS_RSEMA sema;
    OS_CreateRSema(&sema);
    But &sema has also a valid value before OS_CreateRSema() .
    With the debug build of embOS you could check sema.Id which gets a valid value when the semaphore is created.
    But this Id member is only available in embOS debug builds.
    Til
