[SOLVED] Getting output from user actions in Ozone
  • [SOLVED] Getting output from user actions in Ozone
    Is it possible to get the output of the User Actions command inside Ozone?
    E.g. I do Target.ReadU32( 0x80000004) .
    When I do this from Ozone's Console window, command seems runs, but I get no output. Is there special window .. ?
    To enable Ozone log do the following:
    launch "Ozone --logfile <logfile>" where <logfile> is the logfile path. More information are available in the Ozone manual.
    Does this mean you cannot get output of those commands in Ozone 's console .. ?
    Correct.
    The Ozone log will log everything that you see and enter in the Ozone Console.
    Most commands you see in the action table of the Ozone user manual will not print any return value in the Console as they are meant to be used with the Ozone scripting interface.
    For memory reads and writes while debugging we suggest using the memory window.
