I observe that when Edit->Configure is selected in the SWO Viewer, the data rate of ITM data coming out of the target SWO pin changes frequency. That is, the frequency of signal changes. Is that correct behavior?
I also observe that running the SWO Viewer simultaneously with JLinkGDBServer.exe is not reliable. Should only one be open at a time?
Can you suggest any checks when SWO data is going into the JLink SWO pin but data is not displayed in the SWO Viewer?
