[SOLVED] URGENT PLEASE HELP! "no cortex M SW device found"
  • [SOLVED] URGENT PLEASE HELP! "no cortex M SW device found"
    A month ago, I had a fully working development suite...i.e. Keil V5, Jlink, STM32L031-device/eval board.
    After coming back to the project after some weeks, for no apparent reason I now receive the error message "no cortex M SW device found" when I try to download to flash.THERE HAVE BEEN NO HARDWARE, SOFTWARE, TOOL-CONFIG CHANGES MADE. I have even kept screen-captures of all my settings and everything looks as it did before.
    There is something inherently unstable about this Jlink device, the driver and/or Keil.
    Can someone please assist - our company is running behind now due to this! ...I think this must be a known error given the amount of posts I've seen about this, however NONE of the solutions presented had any impact.
    from the output:
    Set JLink Project File to "C:\Users\py\Desktop\Work In Progress\Projects\Segment Remote\Embedded\MDK-ARM\JLinkSettings.ini"
    * JLink Info: Device "STM32L031K6" selected.
    JLink info:
    DLL: V6.20h, compiled Oct 27 2017 16:22:47
    Firmware: J-Link V10 compiled Oct 6 2017 16:37:55
    Hardware: V10.10
    S/N : 50105710
    Feature(s) : GDB
    * JLink Info: Found SW-DP with ID 0x0BC11477
    * JLink Info: STM32 (connect): Can not attach to CPU. Trying connect under reset.
    ***JLink Error: STM32: Connecting to CPU via connect under reset failed.
    Error: Flash Download failed - Target DLL has been cancelled
    Flash Load finished at 17:10:23
    Could you try connecting to the target device using the J-Link Commander? wiki.segger.com/J-Link_cannot_…ty_using_J-Link_Commander
    Could you post a picture of your Commander output when you try to connect?
    What is the J-Link log output when using GDB? wiki.segger.com/Enable_J-Link_log_file
    Could you post the log file?
  • As you did not change your tools, setup, SW versions etc.
    there are only 2 things left:
    1) You have have a bad cable etc. that has bad/unstable connection to your HW
    2) You have changed your application to enter low power modes that inhibit debugger connections
    reg. 2)
    Do you have the nRESET pin of the ST device connected to J-Link, so J-Link can control it?
    It is mandatory to make sure that J-Link can connect to your device, no matter in what state it is.
    - Alex
