[SOLVED] debugging bootloader + application with KDS
    You should be able to use J-Link instead of the P&E device with the same steps described in the linked guide.
    Alternatively you can also use our debug software Ozone: segger.com/products/development-tools/ozone-j-link-debugger/
    There you can load the binary/elf etc. files of your project in one session without needing to switch back and forth between multiple applications and debug right away.
