[SOLVED] ses editor pane
  • [SOLVED] ses editor pane
    when using the editor pane to search/edit the .emProject file the editors slide bar maxes out at the column max instead of the current line max column.
    The include directory line in this file is over 1280 columns so I can not see most of the include directories - therefore it forces the user to search for each directory.
    If I put the cursor on a line the editor should be smart enough to slide to the end of current line
    This is indeed an error and we are currently looking into fixing this issue and making the scrollbar dynamic.
    However we do not encourage editing the emproject file directly. Instead use the Project Options GUI to make sure that no incorrect paths, commands etc. are used.
    Follow up errors that come from manually edited emproject files will not be supported by us.
