[SOLVED] SES include directories
  • [SOLVED] SES include directories
    I added an include directory in the
    Edit Options->Code->Preprocessor->User Include Directories
    -I ..\..\..\..\..\nRF5_SDK_14_A\components\libraries\fifo
    try the build again with the same failure.
    Looked in the project.emProject file and noticed that the include file was added the wrong way:
    -I ..\\..\\..\\..\\..\\nRF5_SDK_14_A\\components\\libraries\\fifo;
    remove the extra back slashes and it builds!
    Then when I use Edit Options again it looks like the attached png file --
    How do I easily fix this?
    won't import windows include directories properly
    The post was edited 2 times, last by kbb64 ().
    The -I option is not required here, only add the path.
    Does that solve the issue with the double backspaces?
    If not try using forward slashes instead "/".
    Looking at the screenshot your provided your user include paths look very wrong.
    They should be looking like in the picture I have attached to this post.
    Make sure to insert only one path per line and do not enter anything else than the path. No options, parameters, special symbols, nothing...
    Does it work then?
    If not could you attach your emproject file?
