[SOLVED] Debugging external binary
  • [SOLVED] Debugging external binary
    I have had good success so far connecting a JLink to an ARM11 board and getting a flashing LED example to compile and execute on the board. I can also step through the program without any issues. I am now wondering if I can debug an externally built binary on my board. It is a small binary (less than 1k bytes) that I can flash to the RAM of the board. Since I don't have the source code though, I cannot step through the program. Is there a way where I can use the debugger to just step through the disassembly without the C or asm file? I am interested in seenig what values are saved in registers at different stages.
    szoshi
  • Hello szoshi,
    Generally that is possible.
    You can do this by simply pressing F11 (Step into) when reaching one of the library functions. Then you should land in the disassembly window where you can now step instruction wise through the disassembly code even while executing "unknown" library code.
