[SOLVED] C++ errors in NRF file that compiles cleanly with other IDE's
  • [SOLVED] C++ errors in NRF file that compiles cleanly with other IDE's
    Error :
    ../../../../../../components/libraries/util/app_util.h:118:55: error: expected constructor, destructor, or type conversion before ‘(’ token
    in this source (written by Nordic):
    #ifdef __GNUC__
    #define STATIC_ASSERT_SIMPLE(EXPR) _Static_assert(EXPR, "unspecified message")
    included from a .cpp file.
    I am porting a project from Eclipse, where this compiles cleanly with C++ using the GNU ARM tools. AFAIK this is valid code, so I suspect my project options or the generated compiler command is not correct.
    I have tried changing Project>Options>Compiler><foo> Language Standard to various values including GNU++14 etc.
    How do you view the exact compiler command in the transcript?
  • More info: _Static_assert should be a compiler keyword since C11. I think the compiler is not recognizing it as a keyword.
    Does SES install its own versions of the GCC ARM toolchain? Maybe my other IDE is using a different compiler ((different version?)
    _Static_assert is only a keyword in C.
    For C++ use static_assert.
    Quite possible that different versions are used. To find out which one ES is using go to Help->About SEGGER Embedded Studio
