[SOLVED] Debugging library functions
  • [SOLVED] Debugging library functions
    I am playing around with the Embedded Studio and have been very impressed with what i have seen so far. I am still only using the simulator instead of actual hardware and had one question about the simulator.
    When i debug my application, I see that functions like malloc are directly linked to via pre compiled libraries. As a result, I cannot see where in source sode a problem occurs. I can step through the assembly code but that is not much help. Is there a way to force embedded studio to compile the libraries everytime so that the source code for such functions is also visible during debug?
    szoshi
  • Hello szoshi,
    The libraries are proprietary and closed source so it is not possible to debug the source.
    But generally malloc does what malloc is expected to do.
  • Thanks for the clarification. I was asking since I have had instances in the past (with other hardware/software) where faulty project settings were leading to malloc failing. Following the malloc code helped me to track my problem. I just wanted to check if there was something I was overlooking. Now that I know this I can try to debug my applications with a different approach.
  • Hello szoshi,
    Should you stumble across a problem that is 100% related to one of our library functions feel free to contact us about such an issue and we will fix the issue in a timely manner.
    This question will now be considered as answered.
