Currently checking out Ozone version 2.52d
Using jLink EDU and thus just the eval.
The device is STM32F407VGT
Everything works fine but i noticed that the peripherals register view only shows USART 1, 2 and 6. The others are gone.
The correct device is set
Project.SetDevice ("STM32F407VG");
And the following SVD files are loaded
Project.AddSvdFile ("Cortex-M4F.svd");
Project.AddSvdFile ("/opt/SEGGER/ozone/2.52.4/Config/Peripherals/STM32F407IG.svd");
Is this a known limitation or even a bug? I was intended to look at some code using USART3 and check that the registry was set correctly, but ....
I noticed that only one SVD file for 407 was available and it has the IG and not the VG extension. But according to datasheet for 407 they should all have all the 6 USART/UART's available, so I do not think this should be an issue.
From datasheet:
"The STM32F405xx and STM32F407xx embed four universal synchronous/asynchronous
receiver transmitters (USART1, USART2, USART3 and USART6) and two universal
asynchronous receiver transmitters (UART4 and UART5)."
Vidar
From datasheet:
Vidar
The post was edited 2 times, last by zainka ().
