SKINNING - font size change using the same skin?
    You could use BUTTON_SetFont() to change the font. If you want to change the font e.g. when clicking the button you can react on WIDGET_ITEM_DRAW_TEXT within the custom skinning routine and change the font accordingly.
    Attached is an example where I change the font if the button gets pressed down and uses the default font when it gets released.
    • TextInSkin.zip
      (854 Byte, downloaded 259 times, last: )
