[ABANDONED] How to disassemble cross-compiled ELF in ozone?
  • [ABANDONED] How to disassemble cross-compiled ELF in ozone?
    Hello, I was looking for a better side-by-side (C-and-assembly) view of the code than what gdb give you, so I am trying out ozone (other people apparently got it to work as you can see here). But after loading up my u-boot ELF file, ozone does NOT show me the assembly (only the machine code) as you can see in the attached picture.
    I would guess this is because ozone doesn't know where my cross-tool chain is--even though I have an environment variable called CROSS_COMPILE. How can I tell Ozone to use this toolchain (I would guess it has to call the right readelf and objdump)?
    Thanks for reading.
    -Henry
  • Hello Henry,
    Such behaviour is not known to us.
    What target device are you trying to debug?
    Does it happen during debug session too or is it shown then correctly?
    If not could you provide us with the elf file and your jdebug file?
